Digital channel has been replaced by blue screen. Cannot retune the channels back as nothing happens when hit digital menu button on remote other than blue light in left corner of tv flickers (as it does whenever the remote is pressed). The digital channels are still viewable through the vcr channel.
SOURCE: digital channels have stopped working, only blue screen!
Try resetting the TV:
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
SOURCE: how to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
