Schwinn Wide Ride Pedal  Logo
Anonymous Posted on Dec 01, 2008
Screeching stair climber
My stepper is screeching, I tried oiling it and it didn't work..what can I do?
Anonymous
Level 3:
President:
  • Master 2,336 Answers
  • Posted on Dec 01, 2008
Anonymous
Master
Level 3:
President:
Answers
2336
Questions
37
Helped
756096
Points
8022
Wide Ride Pedal CTGID0 Screeching stair climber
Que es error 5 tectrix personal climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Screen shows err 5
My Tectrix stairclimber powersup but will not start running
Tectrix Cybex Stepper Personal Climber Parts SPORTSMITH net
You should check your power supply for proper voltage output first. Check for at least 110v. The following video will show you how to use a multimeter.
Cybex 500 stair climbers
I am not 100% sure of your question, but the following link will take you to our page for the Cybex 500 machines.
Cybex Tectrix Stepper Parts for 500S 1000 Climbers Belts Pulley Cable...
Parts
This cable can be ordered from our Website. Please have your exact model and serial number ready. The following link will take you to our Tectrix stepper page.
Tectrix Cybex Stepper Parts Climbmax Personal Climber 2000 3000 Model 150...
The chains sound loud when I am on it
Try lubricating the chains to decrease noise. You can use a grease like the one in the link or a 30 WT motor oil.
Super Lube with Teflon 16 Oz Jar SPORTSMITH net
The chains are dry and it smells like it's burning. What type of oil do you use on the chains? Do you think that is the problem?
use transmission oil on the chains and let it soak in . friction can cause the burning smell from old dried up grease
Star Trac Pro Climber Stair Stepper Sc4130: I have no resistance on my star trac pro upright b...
Star Trac pro unit do not have a alternator and this problem is a lower board issue depending the version their is a 2 watt resistor has over heated meaning a component or components has shorted. I don' know but I believe that National Gym Supply may be able rebuild for a lessor amount and new board will cost $355.00 give them a call @ 1800-496-7278
Need to find part numbers for bearings on a tectrix personal climber stair stepper machine
Those are always marked on the bearing shield itself. Look for a number that looks like this: RS 6802 RS or 6104 R.... it will be a letter/3 or 4 digit number/ letter combination.
1helpful
Stair Climbers screen won't work
Wide Ride Pedal CTGID0 Stair Climbers screen won't work
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
