The Aquabot T4 RC starts working fine, then the left track seems to stop and the right track continues to run, so the Aquabot just turns in a tight circle. What could cause that to happen and how do you fix it?
SOURCE: Aquabot Bravo runs great in one direction but not the other
Thank you for posting your question here on Fixya.com.
Either the belt responsible for that direction or the idler pulley and/or wheel teeth are damaged. The only other possibility would be the drive motor itself is near failure. Try running it briefly upside-down on the deck to inspect the drive components in action to determine which is the problem.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: Aquabot T4 RC, Pump runs for 1 second then shuts
Mine does this too some times. I find that if i manually force the wheels (out of water) to turn slightly and then put it back in the water it works again for a bit. I think something is jamming it but can not find out what the issue is. Let me know if you solve it!
