Hi there -
My Sony Cybershot is now about 2 years old, and recently it's been automatically (and very annoyingly) switching between modes. I'll be using auto adjust and all of the sudden it will start showing me it's switching modes (without the wheel having been turned at all). Today I noticed it's started to switch modes while in-photo, leading to blurry photos. Any ideas out there?
SOURCE: Sony DSC-W50 Flash Error code-E:91:01
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash. 1)at setup do a initialize. 2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again ) by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
SOURCE: Cybershot DSC W50 Flash Doesn't Work
have you tried resetting the camera? i had this same problem and i just went to menu>setup>setup1>initalize>OK and it went away completely.
SOURCE: Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
