Progressive Scan Mode
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
I am very thankful for the solution attempt on my problem. However, the problem still remains. When I scroll down to the speaker set option - there is no speaker set option. It is blank as if the programmers forgot to put it in there, but we know it was in there before. I don't know what else to do because DVD's work but the DTS does not. Does this mean the chip burnt out? If so what is an economical solution for this. Thanks again!
