I got it to record message but it sounds like im in a spaceship with echoes
With the phone in standby mode, open the menu by pressing MENU/SELECT. Select "Ans. Setup." Press MENU/SELECT to start recording. Press MENU/SELECT when done. Press PLAY/STOP on the base or END on the handset to save.
The above is from page 18 of the manual.
SOURCE: want to put a new message for the greeting
Here's a link to Uniden's download page:
http://www.uniden.com/index/manuals_results.cfm?cat=1
Your model is listed there. Just download yourself a copy and you'll have all the answers (and you won't be able to lose it again)!
SOURCE: UNIDEN DECT 6.0 DIGITAL ANSWERING SYSTEM HOW TO
menu, scroll to ans setup then hit menu again, make sure it's on record greeting, menu to start recording and menu to stop.
SOURCE: How do I record a new message please?
There should be a button that reads "greeting".If there is no button that says "record" or "rec",then just hold down the greeting button and it should prompt you to record.It seems odd though,the digital answering machines usually hold their greeting even when losing power and coming back on.If it currently gives a "computer voice" greeting it should not be a problem.If there is no "computer" greeting,there may be a problem.Good luck.
Testimonial: "Thank you for your help and speedy reponse. I will try to set it up when I get home tonight"
SOURCE: I want to change my
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to download the manual.
