best result : just download unlockme.sis application & install it on your nokia 6600 and open it after 10 to 15 minute lock code appear on display .
to remove virus you have to formatt your phone , frist switch of your phone & start the device by pressing combination key green key ,' * ' , ' 3 ' , ' power on/off switch ' you will show formatting on display , make sure that procees remove contacts messages etc. so please back up your data before formatting
What is your mobile and model ? If you forgot the security code you have to reset you mobile. Its the only way to use your mobile again. After resetting you can enter a new security code again. If you use nokia or alcatel mobile means just visit here Simpleunlocking.com for the master reset code service and get the reset code........
If you forgot the Password or Don't know means you can better master reset the Phone what is Mobile Brand and model?
You can get the master reset code from here
Theunlockarena.com and reset it...If your phone is Alcatel and Nokia means get the master reset code there.....
In the System Settings Menu, go to the 3rd page, then select "PARENTAL CONTROLS."
Select "YES," to change the parental controls.
You will be prompted for your 4-digit PIN.
If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
If you don't know either the PIN or the secret question, the Parental Controls will need to be reset.
An Enquiry Number will be displayed. Ring the number given in the Nintendo DSi Operations Manual and provide the Enquiry Number. You will then be issued with a Master Key. Tap "OK" and enter the Master Key. Tap "OK".
Select "PIN" to change the PIN or "CHANGE SETTINGS" to update the setting you wish to change. Once the changes are made, select "DONE" to confirm any changes.
"If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance."
If you don't know the Lock Code means You can master reset your Nokia 5130 Phone,You can get the master reset code from here Unlocking4u and reset the Phone...
Don't worry you can reset the Nokia 1600 from the security lock using the master reset code,you can get the master reset code from here Simpleunlocking.com and reset it.......simply as the website name the master reset also easy.
