Is this repairable/recoverable. Bought this camera less than a week ago. Managed to spill nail polish remover over the screen. Screen damaged - camera will still turn on and take pictures but visible damage on screen. Put in warm place in bowl of rice - any suggestions?
SOURCE: camera batteries drain quickly
Open the battery door and check the contact between the camera and the batteries. Most often then not there is just a bad contact and it's ruinning your baterry life.
Make sure that the contact are well placed and that there is no rust or dirt build up around there.
SOURCE: broken screen
Sounds like the LCD. Setting anything next to it, bumping it may crack the screen
SOURCE: How to disassemble case.
Pry the metal spring clip in the base of the hotshow toward the rear of the camera with a pocketknife, itll pop out and there will be 4 small screws under there, Ill put a buck on that bet. The hotshoe needs some good anchors to support some beefy flash units so it has screws to hold it down, metal hotshoe to metal chassis.
SOURCE: Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
SOURCE: Olympus 1050SW won't turn on after being under water...
Repair center in the Philippines
Quezon City Columbia Global Photo Sales Corporation
#129-1350, ROXAS
STREET, SFDM 1117 Quezon City
Tel: 363-8550, 363-7463
