I have tv samsung model samsung lcd tv model la32c400...when you open the power on. they have a raster but it is hung .up...and then we open again the power booton on pwer it is have only light display ...and also based side have small line ruster only 3cm....what cause this and problem the t-conn....has fixed already in lcd or disposable .....what is the solution on this parblem......some help.....plssss txt me 09991375154 thank u.....
SOURCE: LCD TV vertical line
If the line is vertical and "One Pixel Wide" (Pinstripe) then the LCD Panel is bad and needs to be replaced. Contact 1-800-SAMSUNG to set up service.
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
SOURCE: vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
