None of the HDMI ports respond to either my BluRay player or Bbox (cable TB box). "This source is not connected. Plese check the connection again". All the other ports work. I have tried unplugging everything, and turning everything off. Please help! Thanks in advance.
SOURCE: my samsung tv wont connect to my ps3 through the
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
SOURCE: Broken HDMI Port for HP-R5072
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
