SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Unplug it for a few minutes to see if that clears the code, if not, unplug it overnight. If the problem persists, then you might have a shorted membrane switch on the keypad.
SE indicates a shorted membrane switch on the keypad. Unplug the oven for a few minutes to see if it clears. If not, leave it unplugged overnight. If the problem persists, then you probably do have a switch that's bad.
Since there was no smoke, it's not a transformer. It's most likely a high voltage diode or magnetron. The magnetron would be over heating and opening a thermal cut out mounted to or near it.
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
We have a Samsung SMH9187ST that just shuts off. no power at all. this is the 2nd time it happened, this time my husband was home to witness. First time I somehow got it to start working again , this time no luck. it was manufactured Dec 2009
The
first thing I would suggest is a hard
reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work,
leave it unplugged for about 5 minutes. If this scrambling is occurring a few seconds after you begin a microwave heating cycle, see this FixYa solution even if your model number is different.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
I bought a new close
