Hi my remote control stopped working, after trying batteries that do work on other items (and are not flat!) i thought ok, it is broken , so i bought a universal remote control which works on a LG tv in the bedroom, but not on this sanyo??? i also took a photo of both remotes with a digital camera, to check they were sending a signal, and they were... Is this a sensor problem on the TV?... is it fixable? is it another problem, or won't the TV accept a universal remote? HELP HELP HELP Please :)
From your detailed description, I assumes that the infrared sensor inside your TV has the fault. This part can be loacated just behind the infrared sensor window at the front panel of the TV. You have to open the TV, and desolder it out from position, note the type used, and repalce it. There are so many types of these. Pictures of some are attached here.
Testimonial: "thank you for your help Gopakumar :)"
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
SOURCE: sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
SOURCE: Sanyo tv,RCA universal remote,Diamond Vision player--compatible?
Sorry it took so long to respond to your request for assistance. You can find the instructions and codes you need to program your television at the RCA customer support website [http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web address and paste it into the address bar of your web browser. This will take you to the RCA main customer support page. Just go to the universal remote control section and find your model remote control. Use the model number to find the technical support information page. On this page will be a copy of the owners manual and the remote control codes to use with your products. I hope this information helps you with your problem of needing instructions and codes to use your remote with your products. Thank you for using FixYa and have a nice day!
SOURCE: power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
SOURCE: sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
Thank you Gopakumar :)
