Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
Posted on Dec 01, 2008
Water not draining completely
G e 1430 potscubber uncounter 14yrs in service
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
484
Points
I fixed a similar problem by changing the ELECTRIC ANTI-OVERFLOW VALVE located at the back of the machine.
My GE potscubber water jet is not moveing water . The water is discharging is there help?
most likely ther is a spring returned check ball in the white disk just above the bottom that are known for sticking, but if you open the disk to clean it, you will have to put silicone on the outer edge of the disk and wait a full day before use. if the disk is not sealed well, the washer will not drain all the way.
4answers
Re-assembling a Brother HL-1430
Is that the small piece at the back? It has 2 little click thing that you need to push then insert it to the back of the printer. It would be better if you can send us screenshot or pic of that part?
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Zanussi zwf 1430 washing machine first came up with an e20 error during draining having looked on Internet checked the front filter and grey hose, cleared any lint etc out but now the machine is leaking...
Of course it's replaceable, first find out where the leaking hose is, then look for parts on this very site Fixya. It's actually an easy fix
Helped?
4helpful
What are the 8 kinds of noun?
Kinds of Nouns:
  1. Abstract
  2. Collective
  3. Common
  4. Concrete
  5. Countable
  6. Mass
  7. Material
  8. Plural
  9. Pronoun
  10. Proper
  11. Singular
  12. Uncountable
Classifications of Types of Nouns
Proper Noun: This is used to denote a particular person, place or a thing.
Examples: English is a global language.
Common Noun : This is used to refer to a class.
Examples: The cat loves comfort.
Collective Nouns: This is used to refer to a group or a collection of things.
Examples: I saw a herd of sheep nearby.
Concrete nouns: You can experience this group of nouns with your five senses. These nouns can all be touched, smelt, tasted or seen.
Examples: The cute rabbit hops around.
Countable Nouns: To linguists, these count nouns can occur in both single and plural forms, can be modified by numerals, and can co-occur with quantificational determiners like many, most, more, several, etc.
Examples: There were so many bikes on sale.
Material Nouns : This is used to tell the substance by which the things are made.
Examples: The chair is made of bamboo.
Pronouns: These nouns can take the place of a noun when referring to people places or things. In English the personal pronouns are I, you, he, she, it and they. Depending on their function within a sentence these nouns can take on their possessive forms or their objective case.
Examples: Suzy will let her hair grow longer. possessive personal
He jumped on the bed. singular personal
Abstract Noun: It is used to indicate the quality possessed by a person or thing.
Examples: I appreciate your sincerity.
Uncountable Nouns: These nouns cannot be counted they are often referred to as mass nouns. These nouns cannot be used in a plural form.
Examples: The pool was full of water. The uncountable noun in this sentence is water.
Read more: http://wiki.answers.com/Q/What_are_the_kinds_of_nouns#ixzz1VNQPNpIZ
1helpful
2answers
Dishwasher turns on but no water is going into the dishwasher it is a GE potscubber 970
As there is no water entering the machine, check ;-
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
check your float assy it the round looking item in the front under the lower rack then make sure it get pushed down then try again if not then replace the water valve its gone bad
2helpful
2answers
Toyota Corolla 1994
The hose is called the "water inlet hose"; and there are 2 different ones, depending on your engine size. You will probably not find this at an auto parts store, but, here are the 2 different part numbers, if you want to go to a dealer for the part:
1.6 Litre: 16322-15050 $54.04 US
1.8 Litre: 16332-16060 $44.87 US
This should solve your problem.
Thnaks for choosing FixYa.
18helpful
4answers
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
