You may have to replace the date/time battery. See the instructions on page 124 of the manual.
SOURCE: Powershot A700 camera won't save the date and time
The date battery needs to be replaced. It is a CR1220 "button" battery. Instructions for replacing it are on page 117 of the Advanced Camera User Guide, which can be viewed/downloaded here.
SOURCE: everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
SOURCE: Canon PowerShot A590 camera won't turn on. I have
If you make sure that the memory card is properly seated and the batteries in and the battery door properly closed, then it should power up. If still no success, it may be the micro switch that closes when the battery door is closed.
SOURCE: How do I turn off the date and time stamp on my
The menu on the camera controls the date and time stamp. Turn on the menu i camera mode, there are three choices, Camera, Settings and customize. Time stamp should be in the middle menu. Look for time settings and turn it off. All pictures have time and date always. The time/date stamp just makes it visible in the image.
SOURCE: time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
