please do check if you have mounted ur car seats in proper location. mostly straps are made of leather, elastic, etc which can expand a bit so if ur seat are placed there should be no problem in puting back the straps.please do check if you have mounted ur car seats in proper location. mostly straps are made of leather, elastic, etc which can expand a bit so if ur seat are placed there should be no problem in puting back the straps.
You can't post conmments that contain an email address.
This isn't
a product available in the UK
so we're unable to assist with your enquiry. Could you let us know what country
you're in so we can direct you to the appropriate customer care team?
Hi Beth - First open the footmuff, and set the carseat down on the floor in front of you so you're facing it. Take the harness pads and ****** pad off the harness straps and place the footmuff into the carseat. Pull the harness straps through the holes in the footmuff and press the back of the footmuff into the curve of the carseat. Replace the harness pads. You're ready to go! When you use the carseat, simply put baby in and do up the harness as usual, then do up the footmuff for cosy, safe travelling.
you take the seat belt and put the lap strap thru the back of the carseat and click in in on the oher side pull tight and carseat is secure. the shoulder strap part doesnt effect the safety of the car seat at all
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Usually you just rotate the buckle away from the strap as you push in the release button. Every carseat is a little different so your best bet is to look in the original owner's manual. if yo do not have it, it can be downloaded from the manufacturer's website.
ON THE BACK OF YOUR CARSEAT ARE 2 METAL LATCHES ON EACH SIDE. REMOVE ONE BE PUTING THE STRAP THROUGH AND ADJUSTING IT TO YOUR CHILDS FIT.YOU COULD ALSO PUT IT THROUGH A SECONDARY HOLE IF YOUR CARSEAT HAS ONE TO PROPERLY HOLD YOUR CHILD SAFELY.LET ME KNOW IF I WAS ANY HELP...
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is. first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
i took my carseat straps and cover off to wash them and now they are clean, however i cannot put it back together.
