Microsoft Windows XP Home for PC Logo
jhonik Posted on Jun 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need this disk (Microsoft Windows XP Home Full Version (x0848123) for PC) iso
I need this image ISO disk. Microsoft Windows XP Home Full Version (x0848123) for PC
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Jun 11, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1185177
Points
16067
I'm sorry but this is not a warez site. We do not give out activation/access codes or download links to illegal iso's.
5 Related Answers
Anonymous
  • 184 Answers
  • Posted on Jan 20, 2009
SOURCE: iso image of original xp-3
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&DisplayLang=en
Anonymous
  • 90 Answers
  • Posted on Jan 23, 2009
SOURCE: Windows XP Boot CD Network Boot Drivers
I would try to boot in safe mode, then download the appropriate card driver.
Rakesh Kumar Jangra
  • 88 Answers
  • Posted on Apr 30, 2009
SOURCE: Nlite Windows XP Pro SP2 not recognized
Dear,
You should use Nero 6 or above version. It is very easy to use.
Just create an image of original disc and then burn it on the blank disc.The copied disc will work fine, I am sure.
Please try it.....
Regards,
Rakesh Kumar
Anonymous
  • 62 Answers
  • Posted on May 11, 2009
SOURCE: microsoft windows xp home edition version 2002
looks like 32 bit to me. it is rare to see a 64 bit version of windows XP.
Anonymous
  • 11 Answers
  • Posted on Dec 01, 2009
SOURCE: How to make bootable disk with win xp.iso format?
to answer the first question an Iso file can be burned to disk using the iso
burning function that comes with most burning software. if this file is an operating system then it would automatically be burned as a boot disk and nothing else would be needed. However if this is say service pack 3 and its an iso format then even though your burning it using an iso function it would just be service pack 3 and nothing else a none boo table disk.
2answers
Windows xp3 bootable usb iso file
use yumi to create a bootable usb (the first link)
the second link is the iso file
also it is recommended not to use windows XP as your main operating system. If you are using for research or something else then its alright.
YUMI-http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Win XP SP3 - http://offlineinstallersoft.blogspot.com/2015/03/windows-xp-pro-sp3-iso-download-free.html#.VssLKxjxVxg
there are official links too and also guides.
My windows xp startup disk with the os an drivers is no good microsoft says i need contack manufactures copy do have one
You should not have contact the manufacturer (microsoft)
one of these will help you
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
post a reply if you need more help with this
Windows 7 instaiiation disc
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
When you purchase Windows 7 from Microsoft Store, you have the option to download an ISO file or compressed files.
The Windows 7 USB/DVD Download tool allows you to create a copy of your Windows 7 ISO file on a USB flash drive or a DVD.
To create a bootable DVD or USB flash drive, download the ISO file and then run the Windows 7 USB/DVD Download tool.
Once this is done, you can install Windows 7 directly from the USB flash drive or DVD.
Hope it helps
I have made a disk image, with file extension .wmf, but don't know how to open it and get all the disk data back ??
wrong file extension. if you made a image of the OS it should have been a .iso this is burnable and easy to open with winrar or a dvd burner program for image burning.
The ISO file type is primarily associated with 'ISO-9660 CD Disc Image'. A literal dump of the data on the CD, byte-for-byte. The data is stored in the ISO-9660 format. IsoBuster can interpret these files directly.
The .wmf file type is primarily associated with 'Windows Metafile' by Microsoft Corporation. Microsoft graphic format. Xara X is a good program to edit this file type if you don't have Microsoft tools. There are several versions of a Metafile; each having a different header structure.
2helpful
2answers
I want to make my pendrive bootable to install window xp on my computer
download this file unetbootin-windows-471.exe, then you must have an ISO file of your windows xp, you can install ultraiso or any iso maker available on the web, insert your xp cd then make an iso image out of your xp cd... after having iso file for win xp, insert your pen drive (at least you have 1gig free space on your pen drive) then open unetbootin-windows-471.exe, under the disk image, locate your win xp iso file using the select disk image file button,. then just chose Usb Drive , and also on the drive chose the drive of the usb (check it on my computer and check the drive letter of your pen drive) then click ok... once successful transfer of image to the pen drive, restart pc then make your pen drive to be the 1st boot device
I have an old dell dimension 4300, it is running windows xp. i havent got the system restore disk and when i try to do it through windows it wont let me. How else can i do it?
Well download a disc from here http://www.tipandtrick.net/2008/download-unmodified-original-windows-xp-with-sp3-integrated-full-retail-and-vl-install-cd-iso-image-from-msdntechnet-plus-via-http-or-torrent/ download which ever version came with your computer either home or pro, burn it using a iso burner, and viola' you're good to go on a reinstallation.
1helpful
How to make bootdisk from .iso image
You need to use ISO burning software. Nero has built in features for that, winiso can do it as well, or even microsoft windows xp.
For just windows XP you can download a tool and burn directly. You do however need to have Windows XP SP 2! <--- Important
http://isorecorder.alexfeinman.com/isorecorder.htm
Link to the site with the FREE download. This doesnt always work, but nearly always :)
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
