My Konica Minolta DiMAGE Z10 Digital Camera is not recognizing my SD 32 memory card. (SDC-32M). I've used this card before in this camera successfully. My laptop reads the card. I've taken batteries out, turned camera on and off, reformatted card through the SD Card website, not windows. I've taken the card in and out of the camera hoping it was a loose connection to no avail. I tried to go to the playback menu to format the card through the camera, but it doesn't recognize the card for me to format it, and I can't even scroll through to the format menu part. There is an exclamation mark. by format and delete in that section of that menu. Worst part is, I can't find the stupid cord that goes from camera to pc. Wondering if there's a firmware update if I do find the cord? Any other suggestions?
SOURCE: Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
I havw a konica minolta maxxum 5 d camera the card does not read what can I do
SOURCE: Konica Minolta DiMAGE Z10 no sound?
because this particular model of the Z series does not have a mic. recording. kind of a waste but if you went to another model (I.E.. Z2) it does have the mic. to record. sorry but i went through the same issue myself. good luck
SOURCE: 8 Gb SD card not recognized by Minolta DiMage Z6
The Z6 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
