EZ-Dial:TIMER 7 day pre-set events
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
I need to know how to set the timer for light to come on when gone on vacation for security
SOURCE: I bought brinks ez dial
Smart thinking using wall timer instead of buying new coffee pot.
I'll remember that tip.
I test timers.
A lot of timers arrive defective, and other stop working short while later.
Some last for many years.
On your timer, make sure slide switch is pushed all the way over to TIMER or TIMER ON.
Plug regular lamp into timer, turn lamp ON, and manually rotate timer dial clockwise to see if timer trippers will turn lamp ON-and-OFF.
If timer functions with manual rotation, then see if dial rotates on it's own.
The dial should rotate, or else timer is defective.
If dial rotates, and timer works for lamp, then double check that your coffee pot is ON at all times.
The timer just opens the circuit to coffee pot, but coffee pot has to be ON.
Also take advantage of fixya phone support for any type of problem.
For a price, fixya expert talks to you over phone to resolve repair issues.
Don't know how to program it
Have an EZ dial timer 42-1009 how do you set it to turn off
