I hit a tree with the front right wheel, now my right tire is out of whack, I need to know how to straighten wheel back out?
SOURCE: hit fence and right front tire is towing out. how
kevin plumag, you may have bent the tie rod. It's an easy fix: each end of the tie rod connects to the axle, keeping the wheels at the right distance. Each end of the tie rod has a small cotter pin. Remove the cotter pin (a washer will fall off), lift out the bent tie rod, and put a new one back in, reinstalling the washer and cotter pin on each end.If your tie rod is straight, something else is wrong (which is why I'm searching the boards!). You can order a tie rod from Sears; check your manual for the part number.
SOURCE: Deck may be bent?
On your problem it is diffiuct to say. I don't know how old it is and if it has been run hard in gravel or how many roots you hit. However if the blades hit it hard enough you may have hit the deck brackets. You need to get it no concrte so you can mesure the for corners of the deck on the level surface, then check which side and if it's front or back that is higher. Most likely the lowering arm Is what is bent where the lever you Drop the deck down with is, look tthere first. Also look at the top of the deck and side to side at the lawen mower and see if you can see if the deck is up higher on one spot more than anywhere else. . I know this is confuseing but hope you understand what I am saying. I would also check the front axle mesure the top o the axle on both sides are they even? Yes? then mesure from ground to top of the hood on the lawnmower. Good luck.
