All the buttons at the top freezed. I tried to reset but all invien.please help me cose this irritates me. i can see all my screen clearly but that VOL-0 apperas on the screen & blinking. Thanks
have you tried factory reset by holding power on and vol down buttons most android phones do this some are power and vol dwn or vol up or both keep trying to see which one yours is also some times you may have to remove sim and sd card not all the time but in some cases then just go to factory reset using vol buttons to move up an dwn hope this helps
I'm assuming you've tried to do it from the settings menu but you can't because the phones freezing. Here are the steps for that anyway. If not the external key solution is below Factory Data Reset
From the screen of your phone, press the Menu button
Tap Settings.
Scroll down and tap Privacy
Tap Factory Data Reset
Check Erase internal storage if you would like to erase all the data on the phone internal storage such as applications, music, movies or photos.
Tap Reset Phone
Perform a factory reset using external keys
If you are unable to navigate through the menu to perform a factory data reset, you can follow the steps outlined below:
Power off the phone, press and hold volume down button, press power button
Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
Wait for the "triangle ! / Android" screen then go on to step 4
Press both Vol up and Vol down key simultaneously. A menu will come up
Tap on Vol down key until "wipe data/factory reset" is highlighted, and tap Power key. Another Confirmation screen will come. Tap on Vol down key until coming to Yes and tapPower key
After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower key
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work: Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
You have to perform a hard reset, which means you will lose all of your personal data. Just had the same problem with mine and hard reset it a few minutes ago. hold and Vol Up and Vol Down as you hit the power on. keep holding the volume buttons until you get a diagnostic screen. Hit Vol Down, and your phone will be reset.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
* Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control)
* While holding the above buttons, plug in the TV.
* The TV will turn on with the "K" or "K123" appears om screen.
* Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Sharp AquosLC-32L450M -i have recently baught this LCD, but I think the 'mpx' ie the multiplex sound is not working. there is this 'mpx' button on the remote, but wen i press it nothing really happens. in the manual its only written in one line "mpx- multiplex sound" . please any one can help me ..I m really not happy wit the sound right now. paid so much & no good sound its bit irritatingplease any one help.. wats the problem
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know. If you need further assistance or if this did not help you please comment to this post and I will try to help you further. Thanks for using FixYa asnowman
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps. Dave
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
