It started the first time i started it, but now it wont.
SOURCE: bke wont start
Hi there, try this sometimes the stand switch can make the bike not work if has got rusted at the back.and check or replace the coil., then check if you are getting a spark from the plug by putting the spark plug on top of the head. The next thing is if the bike turns over but not fire up, you need to strip down carb and clean jets, also check petrol value under the tank If you have a book it will go through this step by step. good luck.
SOURCE: water just goy into my muffler and my dirt bike
It would talke a lot of water to get into the pistons under normal circumstances. Pull the plugs and try to give it a kick. If there is water in there, it should come out when you kick it. Check the oil for water contamination. If you find any water, change your oil immediately. Oil should look like honey or it shuld be black. Anything else is contaminatied. If you find water, squirt oil into each spark plug hole and turn your engine over - get local advice from your motorcycle shop.
Thanks for using FixYa.com
a
it turns over but wont start.
