Emerson EWD2204 DVD Player/VCR Logo
Anonymous Posted on Jun 10, 2012
Factory reset ewd2204 dvd player/vcr combo
After using a universal remote, original remote will not work
5 Related Answers
Anonymous
  • Posted on Apr 09, 2007
SOURCE: Emerson EWD2003 DVD Player / VCR Combo has no power.
Check the breaker box for a tripped breaker.
A
Anonymous
  • Posted on Jul 05, 2008
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
http://www.urc.philips.com/
US2-PM335
There you will find all needed information
Anonymous
  • 247 Answers
  • Posted on Dec 21, 2008
SOURCE: I need the remote codes for an emerson dvd/vcr combo
i need the exact brand and model of the remote.
thanks
tom
Anonymous
  • Posted on May 28, 2009
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
Anonymous
  • Posted on Jan 29, 2010
SOURCE: Time warner cable 'universal' remote (UR5U-8700L)
volumn control not working
RCA 4 DEVICE UNIVERSAL REMOTE, NEED 5 DIGIT CODE FOR DVP 3150V VCR DVD COMBO.
Please don't type is all CAPS, it is considered SHOUTING and is harder to read. Thanks.
No one buys Universal Remotes, you buy a remote made for the device, a copy of the original.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.com > itm
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Type: Remote Control ; Manufacturer Warranty: None ; Custom Bundle: No ; Color: Gray ; Model: Philips.
MPN: DVD740VR99 DVD74DVR, DVD740 DV...
Compatible Brand: For Philips
Compatible Model: DVP3150V/37 US$49.91 · ‎In stock
How do i get my original remote control to work on a ewd2204 dvd/vhs combo after using a universal remote
If the remote that does not now work came with the unit--ie it is original and not a universal it should work.
Note that the remote can be tested--all shops use either a card test--it has a strip that reacts to the infrared signal the remote sends and lights that strip.
Some digital cameras in a dark room will react on their display screen in the same way when the remote is pointed at them and buttons on it pressed.
Idea is to find out if the remote is working or not....
Describe your Panasonic PV-D4743 DVD Player / VCR Combo Problem I DO NOT HAVE REMOTE FOR THE DVD/VCR. WILL A UNIVERSAL REMOTE SOLVE THIS? I HAVE A SHARP TV WHICH ALSO LACKS A REMOTE.
Universal remote may give you few controls like power on-off, FF, REW etc but Menu may not open.
Substitute remote for this Combo is available in Remotes.com and original remote is available in Panasonic Parts under part number LSSQ0374
Same thing goes to your Sharp tv.
Thanks.
2helpful
I have a Magnavox DVD/VCR combo that I have lost the remote to. I have bought universal remote after universal remote trying to get one that will work the DVD player or at least will setup the date and...
Universal remote does not work with Magnavox combo of dvd vcr, because no dubbing button. But magnavox has many remotes that will NB884, NB559, NB677.NB627 which also works on Sharp dvd vcr combo.
1helpful
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
I LOST MY REMOTE TO MY DVD/VCR COMBO AND I BEEN TRYING TO PROGRAM A UNIVERSAL REMOTE BUT IT WONT WORK
"Universal" is a joke; they should be called 'multibrand.'
Although their prices are sometimes stiff, they normally have originals for sale:
Remotes
4helpful
Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
14helpful
4answers
URC-3021B00
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
