Cordless phone handset displays searching
SOURCE: phone says searching
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
SOURCE: I have a philips CD
Presumably you have 'registered' the handset to the base station - a bit fiddly, but easy enough! If you haven't a handbook, there is one here
http://www.p4c.philips.com/files/c/cd2454b_05/cd2454b_05_dfu_eng.pdf
Good luck
Jim
SOURCE: Philips CD125 Twin Cordless Phone "Searching" problem
Maybe, RF amplifier chip die or antenna broken.
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
