Not seaport my Kodak EasyShare C875 Digital Camera pls advise m
The C875 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
SOURCE: I have Z612 Kodak Easyshare
I had the same problem when I bought a 4GB card to replace the original 2GB. When I took it back to BestBuy where I bought the camera, I was told that this camera could only use a 2GB card. So, I bought a 2GB card, installed it, and everything was fine.
SOURCE: 4gb sandisk sdhc card
I think the C330 is not compatible with the SDHC cards.
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
SOURCE: i have a sandisk sdhc card but it wont format on
The Z612 uses SD or MMC cards. It will not accept SDHC cards. You'll need to use cards 2GB and smaller.
SOURCE: Why will My Sandisk SDHC
The Z740 is designed to work with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
