TomTom Home now has a fix which corrects the stuttering problems with the computer voice needed for the 'text to speech' function on the GO720. Simply plug your device into your computer and have it connect with your computer. You should automatically see a large fix available which will correct the problem. Download it as I did, and the problem is corrected.
TomTom says the latest application update (8.302) addresses the stuttering problem and is available through TomTom Home.
My 930 did the same. I ran TomTom home, installed all the updates that it recommended and it worked fine. If that doesn't work, your speaker may be going, and you might be eligible for replacement under warranty if it is defective.
I have same problem on GO 920. Synth voice stutters when trying to read road numbers.
The voice on my Tomtom GO 720 is muffled. Some street names are unclear. This happened since i installed an update on the device.
My 720 stutters when reading out directions
My TomTom ONE XL has the same problem
Got the same issue after the last update. (GO 720 T)
Same problem on TT 720 after installing NavCore 8.3.
Sam problem here on a 920T. I also can no longer redirect the directions to the car radio!!!
same problem TT720 with 8.30 upgrade- Australian maps
I have the stuttering problem with my GO 720 since the last update. I hope Tmtom will fix this problem
It appears to be a problem in the new update. It seems that we need to bug tomtom to fix the problem as soon as possible because it is annoying.
Tom Tom GO 720 stutters since last update in December. High speaker volume is never used and the unit is used infrequently for short durations. The unit is less than 5 months old.
i called tomtom support & they said they're aware of this problem. as to when they will fix it, they don't know...
Mine started doing the stuttering after a map update. I wish I had the old map program!!
I have the same problem after an version update. I also now have the screen with three distinct lines arross it. One 1/3 down, the 2nd 2/3 down. The screens is different brightness on the three sections and it flickers in brightness.
I have been having the same problem, keeping it fully charged and running with the power source and freeing up some memory helped to an extent.
Same problem, but when you pick another voice, it goes away.
