E 620 Done defrag then full scan, threat detected asked do i want to move to chest or delete, I deleted then restarted right away. when restarted only have a black screen..
SOURCE: Toshiba Satellite A135-S2376, black screen problem
Just bought a Satellite & had same problem. Toshiba Support confirmed the 'Processor Power Management' fix. Within both the Min AND Max Processor State options you should set BOTH the Battery and Power Adapter options to 100%
SOURCE: unable to watch full screen
While watching a video on YouTube, right click inside the video and remove the tick mark for enable hardware acceleration. That will solve your problem. Its a problem with Adobe Flash Player.
SOURCE: i just bought a gateway nv52 laptop last week and
You are going to think I am nuts....but go to the Norton Support site and get the Norton Removal Software from them and remove the Norton program. The boot the laptop off the Windows Vista disc. Once the windows files load, choose your windows installtion....it will most likely be the only one on the list. Once you choose it, choose repair as the option. Windows will scan your windows installation for errors and repair them if it can by using the files on the cd drive. Once it is done with that, reboot the laptop, take the disc out after it reboots, you don't want to boot off the disc again.
Now, follow the guide below to install some anti-malware and a free anti-virus that does not eat up all your system resources.
Possible Virus and Malware
There is a good chance that you have a virus or malware that is keeping those programs from opening. It does not matter these days what security you have if the door to the web is opened. At the end of this are two links to programs that you should load up and run. The first is MalwareBytes Ant-Malware Tool, the other is Avast Anti-Virus 4.8, install these two and let them perform scans.
Run MalwareBytes first and perform a quick scan, when it finishes, it will ask you to post the results, when it does delete everything it finds.
Run Avast and install it, when it asks, go ahead and schedule a pre-boot scan of your entire system. This should get rid of most problems….
http://www.filehippo.com/download_malwarebytes_anti_malware/
http://www.filehippo.com/download_avast_antivirus/
test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) Sata make sure they have dust free secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
hope this helps
