How to change default language of nokia c2 03 from hindi to english
SOURCE: how to change language from
First go to Menu. Then click on settings. It has d screwdriver icon. Click on it. Then scroll down to 'Phone' which is the 11th button. Click it. There u have the 1st button. language or in hindi it says Bhaasha. Click it. Then u will get phone bhaasha. Clicking it will open the languages. Click on English or any other language required.
Thx....
Try this:
Press the "Menu" button and locate the "Settings" (should look like a spanner), press "Ok" or "Select", once it's opened, locate the "phone settings" (it looks like a phone receiver or like a mobile handset) using the up and down key, open it and then the again select the first from the list (that should be theLanguage settings), once it's opened, you'll see the english language written in english as "English", select it [or you can just select "Automatic" if it's default language was "English"]. Now, the language of your mobile will change back to English.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
SOURCE: to change nokia language from hindi to english
SOURCE: Nokia 6220c change language
as u can change the layout of the menu in this phone ill tell you buy the pictures
settings is the folder with a spanner
phone settings is just a spanner
general is at the top of the list
personalize is at the top of the list (blue and yellow faces)
in that list you have
display
standby mode
tones
themes
language
voice commands
select language (5th in the list)
phone language is the first in the list
hope this helped
