Check whether there is an audio out RCA type sockets at the rear side of the TVm marked as Audio Out. If so, you can connect these sockets to any exterenal audio amplifier, by connecting Av cable in between devices, and can listen audio from external speakers. Picture of AV cable is shown. Keep free its yellow pins. Use red and white.
SOURCE: I have tv sony KV- XJ29M50 when switches on comes on for 10 - 30
shutdown trouble, some leak capacitor need to be replaced
SOURCE: Sony Trinitron WEGA KV-XJ29M50 29" TV
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
SOURCE: Where is the vertical part of the Sony KV-XJ29M50,
The easiest way to identify the Vertical drive IC is to trace the horizontal Yoke coils to the board, the vertical coils to the board must lead to the vertical drive output where the IC is seen normally a inline IC with a heat sink.
Check if the solder joints are weak if so solder and check.
Hello
Vertical output Ic is in the A board itsef. It is an SIL type [Single In Line type] Ic, screwed onto a metal heatsink to radiate heat out of it while working.
OK.
SOURCE: Dimana letak bagian vertikal dari
halo
Output IC vertikal dari himpunan ini dapat terletak di A dewan itu sendiri. Ini adalah SMD [Permukaan Gunung Tipe] ic, mengacaukan ke heatsink meatus untuk memancarkan panas dari itu saat bekerja. OK
