I can no longer access a remote view to my camara using Java. This is needed so I can adjust the motion detection areas as I am getting too many alerts. I use to be able to do this but now I can only do this using local access from the Manager Software supplied by D-Link. Java starts to load but I only get Error Click for Details NoClassDefFoundError aplug$SI. I can only imaging it to be a bandwidth limitation or a router setting but it use to work and as I have not changed anything I do not understand. Thanks for any help. Terry
Unfortunately due to the limitation created by DLink you cannot set up your camera's Motion Detection feature through the MyDlink Application. (I suspect you are going to myDlink and trying the advanced setttings)
Instead you have to access through your internal netwok. Try access the devices webpage by going to windows explorer (my computer) and select the network drop down in the left hand window to display your network devices, Find which camera your wanting to set motion detection and double click it to connect to the devices webpage, same user/pw you used before, except this time it will display the main image under Java and also the motion detection grid
I already new the local access solution, that was not my question. From what you are saying I assume DLink have introduced a new limitation to stop remote access changes as I use to be able to make them. Thanks, Terry
I have setup the Motion Detection on my camera remotely using IE. I am on this forum now because I am unable to view live video in Chrome - I can in IE
If you have an android phone you can install:https://play.google.com/store/apps/detai... This allows users to switch all motion detection on and off, adjust sensitivity and set areas applicable for motion detection
Had I known about this limitation I might well have decided to buy a different brand. I'm stuck with 3 cameras on a remote island - a day's travel each way - and no way to turn on motion! :-(
SOURCE: what should the securicam setting be, to view
Wireless camera security systems are available at many stores such as Wal-mart, Fry's and Best Buy.
These systems can be used to monitor your home and possessions while
away. This article will show how to set up such a system.
SOURCE: How to set Static local IP Address for D-link DCS
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
SOURCE: Settings on Linksys router for the DCS 5220 to
Configuring your Linksys router for remote desktop is a task that's
needed before you can access your computer from outside the network. If
you plan to connect to your remote desktop machine from the Internet,
you need to configure the router to allow traffic to the PC. Linksys is
a common router used on home networks for wireless and LAN
configurations. Configuring your router to allow port forwarding to a
remote desktop only takes a few steps through the graphical user
interface.
