INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Also download the product manual from the link provided below :
1. Look at the indicator light on your Lexmark printer.
You'll need to replace ink cartridges when the light flashes or turns red
instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand
name or purchase a generic version that is compatible with your printer. You
can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the
sides of the Lexmark ink cartridges and pull it out. Dispose of the ink
cartridges in a recycle program like the one at Staples or save the cartridges
for refill.
4. Install the new ink cartridges after removing the
protective tabs. Avoid touching the IC chip when installing the new Lexmark ink
cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print
several pages with the new ink cartridges to make sure you installed the ink
cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
