try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
UNfortunately that sounds like the controle module and you can not have that fixed. only replacement of the part will fix that problem
HERE you can find the drawing and parts. You can also order them here
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
I have seen this several times, and all of the times it has a bad control board. usually if you take the control board out, you can see a visibly burnt spot on the back of it wher a connection has melted. Another possible slowrun time problem could be that the water coming into the dishwasher when it fills is not hot. If it isnt hot, it takes the dishwasher longer to heat the water to temp, and therfore it runs longer. Is the water coming out of your tap reasonably hot? if not you may need to turn up your water heater settings. But if nobody has messed with the water heater, or the tap where the dishwasher is attached and the problem just started then thats probably not it. Good Luck!
