Remote codes
For more details Type in this site name < Electro-help> (DO
NOT copy and paste the site name from here.
Doing so may lead you to wrong place) to search box of your search
engine [not in the address bar of your browser],
and press "Enter". It is an electronic
equipments service help site. Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site,
either at the bottom part of first search page, or at the top of second. Detailed descriptions are there to help you.
SOURCE: Insignia TV code for Sony remote RM-V302
press tv, hold setup til tv blnks twice and release setup, type 10463 then power. 5 digit code not 4 like most.
SOURCE: Code for cable TV remote - 26" Insignia 720p HDTV
I just bought a 32" Insignia NS-LCD32-09 using the Cox (suddenlink) remote and the code 0463 worked fantastically for me, Thanks!
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
SOURCE: Emerson Jumbo universal remote not working with Insignia LCD tv
The code is under Sansui. It's code 135. Don't ask why. But it works and fully functional.
SOURCE: What is the 3 digit code for my Insignia Tv so I
You must give model numbers for BOTH devices (remote and TV) if you hope to get any help.
You should also be aware that if a 'universal' (that's a lie anyhow) remote is older than your set, it may not have the code set you need.
You can try on your own here:
Remotes
You may find the code sets for your remote listed there.
It would be our pleasure to help you with getting your DISH Network remote to control your Insignia TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your TV; here are some of the codes we currently have: 834, 538, 720, 000, 834, and 697. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Insignia TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
