Would like to use Microsoft power management instead ot the Toshiba Power saver utility
SOURCE: toshiba tecra m1 sound driver
Check to see if the sound drive installed properly from the device manager. Try uninstalling the driver and doing a hardware search. Then check the sound settings to make sure nothing is muted or turned down. Some driver need manual adjusting.
SOURCE: toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
SOURCE: BIOS is not appearing in Toshiba tecra laptop M1
You can enter BIOS by holding down F2 after power on. Hope this helps.
SOURCE: toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
