It seems you have a lens error, try giving it a simply whack (not to hard) with the power in and see if it retracts if not then you will need to take it to a repair shop. Good luck
The problem you describe is frequently the result of dirty/corroded
battery contacts in the camera. Try removing the batteries and
cleaning the inside contacts with a fine wire brush, steel wool, or
fine sandpaper. Remove any residue left from the cleaning, then
replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
Hershey, take a small pair of needle nose pliers and try and wiggle the lens and it should work! I just did it with my daughters camara
(Same camara, same error message) Good luck!!
SAME PROMBLEM.
WHAT SHALL I DO
