I can view my videos, pictures, when trying to record, i get the following message, too dark or lens is closed, and the lens is not closed and it is bright. then this message: error occurred please turn off then turn on again I do that turn off then on and keep doing the same thing.
SOURCE: Disk Error when Finalizing DVD
you just need to replace optical pick up of the set. It must be costing abt rs 6500/-
SOURCE: Panasonic NS-DV 65 video camera, Tape not detected?
TRY THIS, (CREDIT TO LABBER) IT WORKED FOR ME
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS HOPE THIS HELPS.
EBEN
SOURCE: Dark LCD screen
Have you tried using a manual aperture setting? Also try the back light function.
SOURCE: panasonic SD H80 Lens cover
Make sure gas valve is turned on. Make sure spark plug is not soaked. If has has a primer, only prime it about 3 times. No more than 5
SOURCE: Error Message
try to format the sd card from the camera and then check if it is usable,if not try another sd card.
