? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
Sounds like the screen is going bad. Isolate the problem by plugging an
external monitor to the laptop. Borrow a monitor from a neighbor,
friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the
old big fat
crt monitors as long as it has a vga cable to connect to your computer's
vga
port. If the Borrowed monitor does not show the rainbow lines, that proves your video card is ok and the problem is
your lcd screen. If the borrowed monitor shows the same rainbow lines it means your video card inside the
computer has the issue.
The video will show
on most systems when you reboot without you having to do anything. Some systems
will require you to hit the FN (Function key) + F1 thru F12. Hold down
the FN key then hit the correct key for displaying on the monitor (F1 thru
F12). The correct key will normally have CRT/LCD on it or it will have
the icon of a display.
old big fat
vga
The video will show
Yes! but it is a good idea to hook a spare monitor to the video output first to make sure there is no problem, if okay! replace the LCD screen. Go to www.ebay.com Type: make and model of the laptop and refine search to screen, a list of sellers will pop up showing the prices.
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
could be 2 main causes, either the LCD converter under or behind the screen under the beizel has failed and is messing up the display, or simply the sreen could have been cracked at one point, either way these parts have to be obtained from toshiba.. EMPR do toshibas spare parts, if you are in australia
