Huawei Ideos X5 Logo
Anonymous Posted on Jun 07, 2012
My phone runs on safe mode how do i solve this?
It keeps restarting automattically
Anonymous
Level 3:
  • Master 661 Answers
  • Posted on Jun 07, 2012
Anonymous
Master
Level 3:
Answers
661
Questions
0
Helped
159686
Points
1804
This problem can be solved by hard formatting your phone in case your phone has this option.
To find our you would have to refer to the manual.
Else, the best option is to go to a service station and ask them to reload the software or the firmware of the phone as it seems to be corrupted.
Regards,
Sajjad
PLEASE HELP TURN OFF SAFE MODE
To get turn off Safe Mode, please try the following.
1. Touch and Hold the Power key.
2. Tap Power off.
3. Once the phone is off, Touch and then Hold the Power key again to restart.
The phone should now be out of Safe Mode.
However, if the Safe Mode is still running after you restart your phone, I would then check to make sure your Volume Down button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, Safe Mode.
If that doesn't work try this...
Use the Status Bar to turn off Safe Mode. Pull down (swipe) the status bar of your Samsung Galaxy S6. Now tap the "Safe Mode" button. This should turn Safe Mode off. Now your phone will automatically restart, so that it boots up out of Safe Mode.
Hope it helps you:-))
https://rankupplabs.com/
Need help on how to disable safe mode box on my cell phone screen
If your phone is STUCK in Safe Mode though and restarting it or pulling the battery doesn't seem to help at all then it could be a hardware issue like a problematic volume key (key might be stuck)
Jun 29, 2017 • Cell Phones
How do I get out of safe mode? I have removed battery for several minutes and power cycled the phone and still it wont do anything when i touch the screen and says safe mode.
You have to do the battery but you also have to restart after 10 minutes do restart again without taking battery out. Leave battery out for 10 minutes before doing the first restart then after the first restart has completely rebooted do one more restart. This should solve the problem,
Will not boot in to windows keep reseting error. 100a biohd -8 hd535-3 hd535-6 hd521-4 hd521-2
boot your laptop in safe mode by pressing F8 while starting the computer. follow this link http://download.bleepingcomputer.com/malwarebytes/mbam-setup-1.51.1.1800. download and install antimalwarebyte while in safe mode. Run a complete scan, restart the laptop, update your antivirus and do a complete scan and you will be good. If your laptop restarts when trying to boot into safe mode, then you need to repair your Operating system with its original disk. This would solve your problem. Please give me a feedback
2helpful
HTC phone in safe mode, can this be fixed
Hi, When you're done troubleshooting problems with your HTC Hero in Safe Mode,
you will need to go through steps to boot it regularly and remove it from Safe Mode.
To do so, turn off the phone. Then while its off, hold the Menu and Power until the phone boots. The Hero should then no longer be in Safe Mode
Start the phone and uninstall apps in safe mode
If your phone keeps restarting, or it starts up but does not display the Home screen, a recently installed application may be causing the issue.
When this happens, try starting up your phone in safe mode. In this mode, your phone does not run any third-party applications. Safe mode allows you to start up your phone successfully so you can uninstall any applications that you have recently installed or which may be stopping your phone from starting up correctly.
To start up your phone in safe mode, press the END CALL/POWER button and hold the MENU button until your phone restarts and displays the Home Screen. You will see "Safe mode" displayed at the bottom-left side of your phone screen. When your phone is in safe mode, follow the same steps in Removing installed apps to uninstall the third-party applications.
After you finish uninstalling the applications, restart your phone and check if the issue is resolved.
Hope it helped.
Thanks for using fixya....
2answers
Fake solve pc issue in windows 7 telling me to turn on security center; this virus has gained access into my world of warcraft account and does not allow me to go to websites by clicking them in google.
Restart the computer in safe mode with networking ie. restart the computer and keep tapping the F8 key on your key board and then choose safe mode with networking and once when the computer boots up you will have only microsoft programmes enabled on the computer install a free anti virus programmes like malawarebytes http://www.malwarebytes.org/ and run the scan and it removes the viruses and then once when the virus are removed just restart your computer and that should take care of the problem.
Hello, I have a question about my computer. Well today i started up my computer and it tells me that it stopped responding or restarted unexpectedly. Then it tells me to run the computer in safe mode,...
hi,am ravi here,you can just select safe mode and run your system it will solve all system errors and will get open win xp os.after that you can restart and run it in normal mode.you wont get destroied any of your data.
1helpful
2answers
Programs and files on my desktop won't open, notice on desktop says I'm unprotected and automatically opens Internet Explorer, virus or what??? How do I get rid of it?
Yes it is a virus Issue
? restart the comp in safe mode with networking i.e. by tapping F8 after restarting the comp
? download and run a full scan malwarebytes... download it from www.malwarebytes.org
1helpful
No programs, no buttons work, mouse works, starts but thats it
Restart and keep pressing F8 key. Select safe mode option. IF it will boot into safe mode ok then go to start->all programs->Accessories->system tools->system restore. REstore computer back to previous date.
If this will not be possible.Restart and keep pressing F8 key and select safe mode with command prompt. In command prompt window type in "chkdsk /r " this will run checkdisk and restore missing files.
Please leave your feedback if issue was solved
C++ run time error
Hi ,
Try loggin on to safe mode and check whether you get the same message ---
How to log on to safe mode - Keep tapping f8 While system boots and choose safe mode or safe mode with networking. --- If no error message do a clean boot.
How to do clean boot --
Click Start - Run - types msconfig - opens system configuration utitlity --- Click on services tab -- check the box hide all Microsoft services, then click disable all ***** click to the tab start and disable all click apply then close and it will prompt you to restart the computer . Restart the computer. I hope it fixes the issue .
Top Huawei Cell Phones Experts
NOEL
NOEL
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
