Washing Machines Logo
saranya Posted on Jun 07, 2012
Jamed in front loaded IFB washing machine tell the solution
5.5 kg
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 08, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
250
Points
0
Plz forward contact no. contact name, address. So we can contact with you. also you can visit our website www.ifbappliances.com for more details.
Regards,
IFB customer care
5 Related Answers
Anonymous
  • 351 Answers
  • Posted on Mar 04, 2008
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Anonymous
  • 1314 Answers
  • Posted on Jun 03, 2008
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Anonymous
  • Posted on Mar 15, 2009
SOURCE: I have j1045 front load
The display should say 5E, this means that it's not draining. unlucky for you as this means you have to replace the drain pump, wich aperently cost about $137NZ. this seemes to be a common fault. i'm not a teck, but I just had the same thing happen, lucky for me i had a warranty.
Other simptoms are the loud racking noise coming fromn the washing machine. home this helps.
Anonymous
  • 154 Answers
  • Posted on Oct 25, 2009
SOURCE: Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
Anonymous
  • Posted on Jan 11, 2010
SOURCE: cannot open the front door
I really did not fix the problem. I think the plastic linkage may have been broken and I was looking for a fixto open the door.
Thanks anyway,
Jim Charlesworth
IFB front load washing machine lo trc Ane indication chupistundhi please help me.
Even translating from Telugu doesn't help. We are a North America website, we only speak English.
IFB WASHING MACHINE TRUCK INDICHATIONE (indication?) SHOWS. PLEASE HELP ME
Use Google Translate.
https://translate.google.ca/?sl=auto&tl=en&text=Ifb%20washing%20machine%20lo%20trc%20indication%20chupistundhi%20please%20help%20me&op=translate
Hi, Our washing machine (IFB frond load senetor Aqua) is stuck at function disable Child lock and not not getting reset.it is stuck from yesterday
Look for two key pad buttons with a line with a smiling child face padlock symbol. Press and hold these two buttons until you see or here a response from the washing machine.
On a 8 Kg model, press and hold + and - Change buttons on the right of the LCD screen simultaneously for several seconds? That's the way to toggle the child lock on and off for this IFB model, https://www.amazon.in/IFB-Fully-Automatic-Senator-Aqua-SX/dp/B00LAXLN5C . On a 6Kg machine, https://www.amazon.in/IFB-Fully-Automatic-Diva-Aqua-SX/dp/B071G3B81W/ref=psdc_1380369031_t3_B00LAXLN5C , the appropriate buttons to hold are the Rapid Wash and No Cold. (These are on the right side of the control panel but to the left of the power button.)
Depending on the machine, the time to hold the buttons may be 3 seconds, 5 second or 10 seconds. You should see and hear some response. However, holding the key pad buttons for too long may re-enable the child lock.
I hope this helps. The child lock on most washers remains active even when the power is removed from the machine. This keeps the program from being activated when you clean the control panel or by a child who shouldn't access the machine. If the problem persists, I suggest checking for a problem with the keypad wiring or contacts.
2answers
My ifb front load washing machine is showing door error, how can i rectify it
the door is not closing properly so not making the door switch contact to tell the controller to go to the next cycle replace the door lock problem solved eric
1helpful
2answers
In IFB front washingmechain AC h1 error is coming what to do
that error occurring due to high voltage in your residing area. We believe IFB Washing Machine protects your machine by tripping. We have GA 400 Voltage Stabilizer to buck or Lower your upcoming Voltage from GEB. It has Capacity of 12 amp and 15 to 20 Voltage up /down capacity. We are sure this GA 400 model will solve your problem. You can Call on : 9722658052 or 9427347880 Thank You
1helpful
2answers
IFB washing machine front load Showing ' Lo' what
In IFB Machine LO Error Code indicates Low Voltage Problem. We have the best quality Automatic Voltage Stabilizers. Gelco Automatic Voltage Stabilizer GA400 model will solve your problem. GA400 Voltage Stabilizer to up or down your incoming Voltage from GEB. It has a capacity of 12 amp and 15 to 20 Voltage up / down capacity.
We are sure this Gelco GA 400 model will solve your problem.
You can Call on: 9722658052 or 9427347880
Thank You
I have ifb 6 kg front loading washing machine.my problem is that whenever i put clothes in it ,after 30 min of washing it shows error 7..how to fix it? please help
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
Top IFB Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
