I have a Polaroid TLA-04641C and whould like to have the volume control adjust the volume for the audio out (external speakers) through the TV remote. Is this possible?
SOURCE: Polaroid TLA-04011C LCD TV remote codes
I have the TLA-04011c and have yet to find a code. Out of curiosity, have yall? thanks
SOURCE: Remote code for dish network
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
Let me know if this helps and please rate the solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
SOURCE: tla-04641c won't turn on
my tla-04641c stoped taking commands the day after using it with my laptop and was stuck on so i unplugged it and now it wont turn on when i plug it in the red light comes on and i hear the relay click button nothing happens when i push the on button. any suggestions? i pulled the power board and nothing "looked blown"
SOURCE: I have a 46'' Polaroid HDTV model TLA-04641C
It hasn't been 'unplugged' until you have let it stay that way overnight. There are components that need to discharge and that can take hours.
You wrote 'standard sounds;' did this mean audio or something else?
If you have normal audio but no identifiable video, then the backlight or the inverter for the backlight has failed.
If audio is present, try looking at the screen from several angels to see if you can identify some ghost-like video.
If so, then the above suspicion is pretty much confirmed.
I hate that the modern sets seem so prone to failure, it isn't a good trade-off for the increase in quality of the results.
Most of these are not poor engineering but the effort to build them with the cheapest possible parts inside, often only saving a few dollars, but ruining their reputation.
