Got a heat related issue likely on main signal board---might be able to localize it (suspect a flat pack chip) with a hair dryer to heat the board just a bit.
If the main menu comes and goes off then it is possible that there is a fault in the processor memory. Try and reset with the given code- refer to manual, if not switch off set for about 6-12 hours and press down the panel buttons to drain off all residual voltage . this might help to reset.
Hello The problem is with its main system control processor IC. You ahve to contact any experienced service tecnician to rectify this fault. It is a very skilled job.
Hi Try hard resetting it.This procedure may erase all changes effected on the i phone Press and hold the power button and the menu button.Wait until the apple logo appears.
first u remove the cells of remote. if the menu appears then we are sure that remote is working properly & fault is in tv. then find the menu button on the front panel. when menu appears operate with panel switches. if menu disappears & come again it means that any of the front panel switches is stuck. u need to replace the front panel switches or if it does not disappers the main board is defective.
