When connected via the USB cable the data transfer icon appears on the camera screen but the options box does not appear on the computerdesktop
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Yes. Please use the battery or dedicated AC adapter. For transferring large size of images, using AC adapter is recommended.
SOURCE: Retracted USB charging connection
Mine which charges OK also has a slightly recessed connector
SOURCE: Minolta Dimage A1
I bought a card reader and use it instead of directly connecting to computer with camera. Saves battery life and cost under $30 canadian. Simple file transfer this way. At least your camera is still working! Mine is dead and Sony says no parts available.
SOURCE: I CAN TRANSFERE PICS FROM CAMERA TO COMPUTER
Camera has repair prob, It would cost less to just take the card out and use a card reader, And faster Your problem can be fixed but I think it needs a new power board, $165.00 to fix.
