Maytag Dependable Clean Top MAV5920EWW Top Load Washer Logo
Steve Posted on Jun 06, 2012
Maytag washer # MAV5920Eww. Too much water remains after spin cycle. How to repair.
  • 2 more comments
  • Steve Jun 07, 2012
    I opened the lid while in spin mode, spins very fast. The load was balanced. All hoses and drain OK. There is no water in the tub when not in use. I removed the water pump and rinsed it with water. Still too much water remains in the clothes.
    Even after 2 spin cycles, the clothes are still wet
  • Steve Jun 09, 2012
    I can't change the programming but I repeated the spin cycle and still had too much water in the clothes.
    I appreciate the help; keep it coming until the machine is fixed.
    Is it the water pump that needs to be changed?
  • Steve Jan 08, 2013
    I had the machine checked and the transmission is finished; therefore I had to buy a new machine. Thank you to all who tried to help. Case closed
Shaun Vermaak
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 34 Answers
  • Posted on Jun 07, 2012
Shaun Vermaak
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
34
Questions
0
Helped
7136
Points
94
Can you create custom programs? On my top load washing machine I add additional spin cycles to the program.
5 Related Answers
Robert Siegel
  • 36 Answers
  • Posted on Jan 03, 2009
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Anonymous
  • 151 Answers
  • Posted on May 03, 2009
SOURCE: clothes come out from washer soaking wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Anonymous
  • 3361 Answers
  • Posted on May 10, 2009
SOURCE: Maytag washer MAH 5500bww
Open the rear panel and remove the drain pump and clean it.
If there is nothing in the pump, check the drain motor for 18 ohms with a volt/ohm meter.
Not 18 ohms, replace the motor.
Anonymous
  • 67 Answers
  • Posted on May 18, 2009
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Anonymous
  • Posted on Jul 20, 2009
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
1helpful
Won't drain during spin cycle and leaks
You need to replace the drain pump on your unit. I see this problem about 8-10 times a month with this model. The repair is simple and will only take you 10-15 mins. Here is the part to order.
Here is a video I found to help you make the repair.
Mav5920eww washes and spin at the same time
Its definitely the clutch spring gone bad in the transmission which means you will need to replace the transmission.... it is a common issue with Maytag washers and i do suggest you fix it, most new washers on the market today are complete trash.If you need further assistance please don't hesitate to email me at [email protected]
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Maytag dependable care LAT8435AAE fills with water then quit. Has power but will not start in any cycle
You need a new timer. It's an easy repair ...
http://www.repairclinic.com/Maytag-Washing-Machine-Model-LAT8435AAE-ID-90821-Circuit-Board-Timer-Parts
13helpful
2answers
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
