Need to know how to remove a cassette from a gravity games mountain bike with home tools
That woul depend on what type of cassette it has but regardless of that either type requires a specialty tool to remove. the most common one is a chan wrench and the other is a custom socket fitting. for the chain wrench wrap it aeound the cassett so that when you apply tension you are spinning in the direction that locks the cassette, it takes a good amount of pressure to pull a cassette so if it doesnt happen easy dont be suprised. the socket tool does the same as the chain but instead fits on the inside of the cassette in the hub bearing. remove your skewer before trying either one of these things and if you dont already have the tool your probably noy qualified for the job at hand. take it from a bike tech w/out these tools you will not get it to come off w/out ruining it with home tools. most shops are pretty chill, if you just bring in the wheel and ask em to pop your cassette it takes 2 secs so they probably wont charge you and if they do their a ****** shop.
SOURCE: back tire changing on mongoose gravity games bike
If you have pegs on the back you will need a deep socket to fit the nut and a socket extender and a socket wrench. with the wheel off it is just the same as changing any other bike tire. Just make sure you check the inside of the tire carefully for anything poking through that may puncture your new tube. Also check to see if you need a new tire and make sure you inflate the repaired tire to the correct pressure or you may get a pinch flat.
SOURCE: Frontier GSX Women's Mountain Bike: what is proper way to remove and re-install the qu...
Unhook the front brake, loose the quick release level and push the tire off the fork. reverse procedure to install.
SOURCE: I have a CCM mens
Not really. http://www.parktool.com/blog/repair-help/cassette-and-freewheel-removal
Take it to a bike shop if you don't want to buy the tool.
SOURCE: Need detailed description of cassette
Schwinn doesn't make cassettes. You want details but don't provide any.
A simple web search for "cassette removal tool" leads eventully to http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
