I need unlocking codes plz
It is not safe to unlock your mobile for free, because free unlocking services are not genuine may cause problems to your mobile, hence go for a cheap service. I would recommend TheUnlockSpot.com for genuine and cheap unlock service.
SOURCE: unlock codes...
1) In main menu select the Manage connections icon & turn all connections off
2) Select the option icon in the main menu then select the Advanced option
3) Scroll down and select Simcard
4) First type MEPD, select the network as Yes then type MEP2 (it will not be visible) and then type the Unlock code
5) Press Enter to finish.
After doing all the above steps with out switching off the handset remove the batery and sim after few seconds reinsert them again.
SOURCE: how to unlock blackberry 8520 using unlock code?
Dear,
It is NOT recommendable to unlock your blackberry from free codes because it leads to errors and technical difficulties. If you want to unlock your blackberry, then Blackberry Unlocking codes with IMEI has the best solution for you. Blackberry unlocking codes with IMEI provides you trusted and CHEAPEST codes ever. I hope it would help you.
SOURCE: unlocking codes for blackberry
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
SOURCE: how do i get an
It is very simple to unlock your Blackberry 9300 through Blackberry Mep Unlock Code. call your service provider . or buy your Blackberry 9300 Mep Code from third party. it is safe and trusted method to Unlock your Blackberry 9300.I hope this will help you :)Good Luck.
