SOURCE: I have the Intex Above
Shock the pool with 4 gallons of muratic acid if its a 28,000 gallon pool. Normally that would be a 26 foot wide by 4 feet deep
SOURCE: it says low flow, how can i fix it
Low flow means there is insufficient water traveling through the cell to make CL. Is your cell clean and clear? Is your filter clean and clear? Clean your cell according to the manufacturers instruction and back wash your filter.
SOURCE: My water is cloudy and
Check the electrolytic cell!!! You will get a low salt alarm if cell has calcium or sodium build up.. If it does, soak, flush and clean with vinegar.. Also, make sure you run the pump only, no chlorinator for 24 hrs to properly disolve the salt you just put in....
