I would like to turn up dev for max out put as no doubt factory set
SOURCE: PEEK IT
not a good idea to do it yourself you need the proper equipment to do the alignment you must know what part is the transmit and what is the recieve.
SOURCE: cb problem have a cobra 19dx iv with a 2ft magnet
Hi and welcome to FixYa,
Which output is muffled, transmit (modulation audio) or receive audio?
If you are referring to the receive audio, initially, have you tried an external speaker? If it works good, then it would be an internal speaker problem; if not then others to check would be:
if it were transmit / modulation audio, try replacing the mic.
Please postback updates.
Good luck and thank you for asking FixYa.
SOURCE: I Have A Cobra 19dx
check the swr's on the antenna. all shops should do it for free just to check them. WE DO here in texas.. but if antenna isn't install properly then it may be high swr causing short distance.
SOURCE: cobra 19dx iv when i
Just buy a factory built antenna/(it should be close) Buy you a magnet mount RADIO SHACK job(works). If your indoors buy ANTRON A99(set at 1.3 SWR factory). If it keys 9 db then that equals 4 watts output thats OK.
