I was trying out the option for closed caption and now that they are turned on....they CC icon on the settings screen is greyed out. Even though I can see it, I cannot change it to CC Off mode. Anyone have any ideas?
SOURCE: Can't turn closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
SOURCE: We can not get CC Closed Captioning to turn off.
had a power outage and it said to reset the clock I went some where and changed the close caption from off to on. It was a in a set up menu
SOURCE: LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
SOURCE: We just bought a 42'' Insignia, but we cna't get
Did you check settings on the CATV box the also have CC settings. About the gray out maybe your TV is not capable to do CC. Try that!
SOURCE: I just bought an LG LD450 42" tv and the closed
Hi, my name is John. Welcome to FixYa. Once you get to where it is greyed, press the + button. Thanks for choosing FixYa....John
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
I emailed LG tech support and they said if the closed caption option is "greyed out" then it was my cable remote over riding my tv options. I wound up calling the cable company and they explained that I had to turn off closed captions on the cable box settings. It worked! Now I can turn CC on and of as needed. The cable company tech support also told me that pressing the A button on the cable remote would turn CC on or off also. That worked.
No, I found out by another person from the LG tech support line that the cable box was over riding the settings on the tv. I had to go to the settings on the cable box and turn it off. The CC option was not accessible through the tv remote. That is why it was "greyed out" and not lit up like the other options. The problem is solved and I hope others read my solution so that they can fix their "greyed out" CC option problem. I'm sorry bonifacio gomez. Your solution suggestion was what I had been trying for 4 hours. It did NOT work. Thanks anyway.
