Field Value Motherboard Properties Motherboard ID 08/01/2007-P4M800-8237-6A7L6009C-00 Motherboard Name MSI PM8M-V H (MS-7104 v2) Front Side Bus Properties Bus Type Intel GTL+ Bus Width 64-bit Real Clock 133 MHz (QDR) Effective Clock 533 MHz Bandwidth 4267 MB/s Memory Bus Properties Bus Type DDR SDRAM Bus Width 64-bit DRAM:FSB Ratio 1:1 Real Clock 133 MHz (DDR) Effective Clock 267 MHz Bandwidth 2133 MB/s Chipset Bus Properties Bus Type VIA V-Link Bus Width 8-bit Real Clock 67 MHz (ODR) Effective Clock 533 MHz Bandwidth 533 MB/s Motherboard Physical Info CPU Sockets/Slots 1 Socket 478 Expansion Slots 3 PCI, 1 AGP RAM Slots 2 DDR DIMM Integrated Devices Audio, Video, LAN Form Factor Micro ATX Motherboard Size 190 mm x 240 mm Motherboard Chipset P4M800 Motherboard Manufacturer Company Name Micro-Star Int'l Co.,Ltd. Product Information http://global.msi.com.tw/index.php?func=prodpage2&maincat_no=1&cat2_no=170 BIOS Download http://global.msi.com.tw/index.php?func=downloadindex
SOURCE: Motherboard Drivers
What make is your motherboard? If you open up the case and there should be info and model number on it. The just go to the makers website a get appropiate drivers.
hope that helps :)
