SOURCE: hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
Hi:
Sounds like you have the wrong polarity in your machine. If you are using flux core wire, make sure to connect your ground clamp to the positive side and your gun to the negative side. Dial the right voltage and wire speed according to wire size and metal thickness.Let me know if this help.
Regards,D.S.
