Question about Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array
The 'protect light' comes on Fender PD150 Portable Sound System
When we plug in our Fender PD150 Portable Sound System, a 'protect light' comes on and we can't power up the unit.  We tried swapping out the fuse but it didn't fix the problem.  Any ideas?
  • 1 more comment
  • cindi334 Dec 02, 2008
    Thanks Simon for responding.  I was hoping it was something simple like a bad ground or fuse but it's looking like it is more complicated.  The warranty 'just' ended and I'm hearing sad stories about other owners of Fender Passport systems :-(
    We are looking for a repair person.
    Thanks for the advice.  Cindi
  • cindi334 Mar 15, 2009
    Thanks Simon.  We still haven't been able to fix the Passport yet.  I just took it to our local high school electronics class.  The teacher is said to be a 'wizard'.  But...he hasn't been able to fix it yet.  If it's not too much trouble, the details would help and I'll give them to him.
    Thanks again for the help.
    Cindi
  • lyss_adams Apr 19, 2009
    We have a PD250 that has served us well giging regularly for 2 years. Although yesterday the red protect light came on when we powered on the unit.  We changed the fuse, changed the cable, disconnected the speakers, all to no avail.  We live in Mexico where there are no authorized dealers in our area.  I am interested in what BKFlorida responded about fixing this yourself.  Please help we have another gig in a few days and need to get this fixed asap.  Thanks!
The protect circuit is activated by a current sensing transformer in the *input* of the power supply. If any of the subassemblies of the unit (or all of them in combination) draw excess current then the protect light will illuminate and the power supply shut down to prevent any damage to the system.
The circuitry in the power supply is fairly robust as well as fuse protected so it is unlikely that the power supply itself has failed. More than likely one of your output power transistors has been shorted and it is easy to check this yourself if you are interested in doing so.
Furthermore if you follow a few *simple* precautions you can do this safely and confidently.
Post again on this thread if you are interested and I will spew the details.
-BK
Posted on Mar 14, 2009
  • Ginny Daniels Jan 24, 2011
    this sounds like the problem I am having. I am interested in the details you have on this.
  • Fender Master
  • 5,603 Answers
Repaired a PD250. The energy storage inductor in the power supply is a bifilar wound toroid. It had overheated and the two windings shorted. I rewound it, and unit operates but the inductor really runs hot. Fortunately the insulation on the replacement wire seems to take the heat.
Posted on Jul 25, 2009
Although it would be much easier to diagnose the problem if Fender made the wiring schematic more readily available, BKFlorida's response is enough for me to fix it! Just count up how many different circuit the power supply secondary supplies, and start isolating them one at a time by disconnecting, testing, the re-connecting the circuit. When the problem goes away, you've found the defective circuit.
Posted on May 19, 2009
    Scholar:
  • 62 Answers
My old band had a similar problem with a different system and we had to return it.
Usually when it does that, it means that there is a short somewhere in the unit and the protect light is a way of preventing the system from overheating and becoming a fire hazard. We kept blowing fuses right before it finally failed.
If your out of warranty, look for electronics repair shops locally.
DO NOT attempt to repair it yourselves and there is more than enough power to stop your heart in there. It's designed to take a small electrical signal and step it up so were definitely talking LETHAL!
Hope this helps,
Simon.
Was I Helpful? Let Me Know By Rating Me?
Posted on Nov 28, 2008
Anonymous
SOURCE:
The "PROTECT" light indicator came on and now the
The protect light generally comes on when the is a short in the speaker cabling. as a test, turn on the mixer without any speakers hooked up. If it still goes into protect mode the problem is in the mixer. Take it to your local music store and have their tech look at it. if it doesn't go into protect, check the speaker cables by plugging them in one at a time. The bad one will send it into protect.
good luck
Sep 12, 2011 | Fender 150 Watt PA System
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
Protection light came on then went of now i get nothing when i flip the switch to on.
Likely an overload failure caused the protect light to come on, and then the fuse blew so all power is off... Do NOT replace the fuse as you will LIKELY do additional damage to components. Take unit in for repair immediately.
Note: These units are really hard to work on due to the way they are packaged.
Nov 23, 2010 | Fender Passport Deluxe 500watt Sound...
The protect light is the only light that comes on
Either one of the amps or the power supply has blown. The protect light means the power supply has been shut down due to overcurrent. Take unit in for repair. These are hard to work on due to packaging.
Oct 10, 2010 | Fender Passport Deluxe 500watt Sound...
We have a Fender P-250 PA system. We get the protect light on when we turn on the system rather than the green power light. We can not get it to operate. Please advise... Gary
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
Sep 23, 2010 | Fender Pd250 Passport Deluxe 250watt...
Protect light comes on when power on
This indicates either one or more of the amps have a failure OR the power supply is being overloaded which is usually also caused by failure in the amplifier.
Occasionally a power supply failure causes this problem as well.
Due to the way these are packaged, they are a real pain to work on for repairing.
Feb 19, 2010 | Fender Passport Deluxe 500watt Sound...
Power indicator light is red and the system does
It is an indication of a bad speaker cable providing a short. If it stays lit with no speaker cables plugged in it is an indication that it needs to be serviced.
Oct 17, 2009 | Fender Passport Deluxe 500watt Sound...
My Fender Passport stays in protect mode.
I have one that has done the same. It is the next smaller size. The power supply fried a toroidal inductor in mine. Frankly, these things are a major pain to work on. You have to usually remove the front panel before you can remove the back power supply and power amp section.
If you have warranty coverage USE IT !!!
The protect feature in mine monitors the power supply load and shuts down the supply if it senses overload. They are hard to work on as you have to bypass the protect to troubleshoot and get to the root cause.
Use the old light bulb in series trick to limit the current.
Sep 23, 2009 | Fender Passport Deluxe 500watt Sound...
No sound from speakers
Page 8 of the owners manual explains this and suggests that if their procedure fails to take it into an authorized Fender dealer for service. The manual is dowloadable at Fender.com/support.
Dec 15, 2008 | Fender Passport Deluxe 500watt Sound...
Fender Passport Deluxe 500watt Sound System with Deluxe Speaker Array Logo
3,632 people viewed this question
Top Fender Music Experts
Michial Gueffroy
rjivaro
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
